Old 07-02-2011, 02:32 PM
JensR JensR is offline
Default Re: CAT 14M Motor Grader
Very nice again, Ari!
I like how the circle side shift cylinders fits neatly even at full lift!
I notice a bit of slack when you lift the grader up, but that is admittedly a rather extreme manoeuvre!
What is the maximum clearance between the blade and the ground which you get?
Original has:
Maximum lift above ground 16.5 in
Maximum depth of cut 17.3 in
http://www.cat.com/cda/layout?m=308648&x=7
In 1:14.5 that would be 28mm and 30mm.
Cheers
Jens
Old 07-03-2011, 02:03 AM
Original has:
Cheers
Jens
I have some temporary loose bolts in all of the joints in the mechanism, so most of the slack is due to those bolts.
I can get the blade 26mm off the ground, and then the center shift cylinder starts to get pinched. Downward it goes about 35mm.
Old 07-03-2011, 07:08 PM
That's great!
I hope I do not sound too critical - I think your project is a dream!
