Old 07-03-2011, 06:52 PM
skl1cent skl1cent is offline
skl1cent is on a distinguished road
Default Re: Rollback tow truck
i really like the center caps on your back wheels where'd u get those?
Old 07-03-2011, 08:41 PM
firefighter30's Avatar
firefighter30 firefighter30 is offline
firefighter30 is on a distinguished road
Travis, the truck and center caps look really nice, good work.
Doug
Member of the East Coast Mini Truckers
Old 07-04-2011, 12:02 AM
Thanks Doug I am glad you like them.
They are real simple and easy to do. The caps are just snap caps epoxied to axial hub nuts used on the ax10. Link to axial caps To do this you need to replace the thick lock nut that holds the wheels on with a regular thin 5mm nut using some loctite. By doing that you will expose more axle shaft threads for the axial hub nut to screw on to. The axial hub nut would probably be enough to lock the other nut from coming off but I put loctite on just to be safe.
Here are some pics of today's progress. New chassis done, cab painted, and a good start on the bed lift and slide mechanism.
Thanks for looking.
