Thanx Tom.
I'm quite pleased with the model so far, absolutely incredible digging power that I have never experience before with the smaller models (obviously). ![]() But I need a different radio b/c the DX8 only has 5 proportional chs, 4 on the sticks & a dial. The Sabertooth will not work with a 3pos switch & the dial. I also need a better swing esc, as the MTronics Viper Marine that I have been using for the trks, the "forward" side of the esc swings smoothly, but the "reverse" side of the esc kinda pulses/hesitates, it's especially noticeable if I go too fast. You can see in the vid when it swings right. And also, the Sabertooth I have is the 2x12, I should be using the 2x25 b/c the model is just so heavy & travels way too quick, the 2x12 over heats quickly & shuts down. The gh motor should have a higher reduction - slower rpm so the motors aren't working so hard, drawing high amps. Jammer & Kalle are already quizing Vario fora group bargain deal on the new track drive system that the model now comes with, they thru my name in there too ( thanx guys ![]() I've only got about an hour run time on it thus far, going outside right now to work that pile over some more. ![]()
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
