Old 07-24-2011, 01:36 PM
SmallHaul's Avatar
Default Re: Wedico 966G Build
Those lines are routed the same as Jimmy's loader that I have worked on and they seem to be ok routed that way.
Make sure you use a good amount of loctite on the little screws that hold the wheels on the axles because they can work themselves loose. After having I wheel come loose, I pulled all of the wheels off of Jimmy's loader and used blue locitite on all of the wheel axle screws.
Scott
"No load is too Small"
Old 07-25-2011, 01:18 AM
pigeonfarmboy's Avatar
Despite all the weaknesses I hear about these Wedico 966Gs, I still think they are great looking models. Everytime I see a picture of one freshly assembled, I want one, but it's a lot of money to fork over for model. Hope it'll be a good machine for you.
Yeah I read many negative reviews on the WDC 966 but ultimately I chose it because of the level of detail it has over the Stahl. It's probably a better idea if you're heavily using a model to go with Stahl but time will tell with this one.
