Old 07-29-2011, 01:58 AM
tracksntreadslou's Avatar
Default Re: CAT 535C Grapple Skidder
Hey ben add another seperate receiver pack ..Had that same problem
Old 07-29-2011, 10:19 AM
JensR JensR is offline
Edit: Just saw that you already run a receiver pack. Unless this is very weak, my following text won't apply to you.
If you are relying on the ESC's BEC and your servos draw a lot of current, the BEC might break down, which shuts off the receiver and hence the servos' current draw. Then, the system comes back to life, with the control stick at whatever position it was and the self-learning ESC takes this as the new neutral.
So maybe, all you need is a stronger external BEC?
I use 5 cells of my 12V pack (it's actually a double 6V pack) to power my receiver. Not ideal, but enough grunt.
Cheers
Jens
Old 07-29-2011, 02:53 PM
Where did you get the tires from? Are they about 30.5-32?
regards,
Frank
Old 07-30-2011, 10:19 AM
Snochaser's Avatar
They are Proline Mashers (discontinued)
