Old 08-08-2011, 11:10 PM
Default Re: Mack M75SX
Originally Posted by ihbuilder View Post
thanks Rob I got the back milled out just off the mill 30 min ago ( I'm gona get some sleep ) everything went well till the drill cycle for some azz reason my holes are out .125" I should have waited and bored the 2 together manually
looks like the verizon strike is effecting my I-net
Hmm, Did you forget to take .100'' off from the edgefinder?
Any pictures of your set up on the machine?
Old 08-08-2011, 11:22 PM
yes I remembered that other wise the backside pocketing would be off . It may be that when using the cam I clicked on the circle edge and not center I'm not sure you can see it in this vid http://www.youtube.com/watch?v=XLyOWczx1DQ
if not I'll take a pic when I do the other side or a trailer frame I'm going to set up . It's basically a fence that I can bolt the stock to .This trailer frame set might take a few days + igot to get more plate for the othe side
Old 08-09-2011, 07:56 AM
For drilling, I draw points to generate the code .
Old 08-09-2011, 07:57 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Looking good!! And everyone thinks that running a CNC mill or lathe is just push the go button and everything comes out OK Slowing down the feedrate is not that bad of a thing to do. Recommended feeds and speeds are not all what they are cracked up to be!!!
LYNN
Old 08-09-2011, 10:48 AM
yea I just looked it over clicked the circle not the point
thanks Lynn , tell me about it I tried to tell my wife that now she gets it , I just never spent so much time at the puter then the machine I cut the recomended feed down by 30% seems to work well I just worked up the next op for those trailer frames with the other frame in it 12 hrs I'm thinking I need to find a water jet guy for the basic profiles
Old 08-09-2011, 09:08 PM
"Any pictures of your set up on the machine?"
Steve , as I promised also this time I decided to use a bigger EM and crank the feed up also the spindle much better time
more tomorrow
Old 08-11-2011, 09:59 PM
well the 2nd frame fell out of the plate this morning about 3 am
Old 08-12-2011, 08:09 PM
walking beams
now these get chucked up in the lathe to turn the ends where the arch stops . there's a pic of it I just got to figure how to get it on here
thanks for looking
