Old 08-09-2011, 11:04 PM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: Pete 357 tri-axle dump update 8/7/11
Thank you gentlemen! Nick I did make those myself, it was a real pain! they didnt come out too bad, I just wish I coulda used smaller screws, but oh well.
Brian
Old 08-17-2011, 03:51 PM
ihbuilder's Avatar
hey Brian those a/c's sit a little higher then what I usuallty make ? looks like it
Old 08-17-2011, 04:42 PM
Snowman's Avatar
Snowman Snowman is offline
Snowman is on a distinguished road
Please feel free to shoot me down in flames if I'm wrong, but maybe the aircleaners look higher or at least different because it's a 357 rather than a 379, so I believe the hood slopes compared with the straight hood of a 379, and it may be shorter too. Maybe that's why it looks different??
Nick
My Peterbilt build thread:
Old 08-17-2011, 09:22 PM
Nick you are correct about the hood being shorter and sloped. The 357 is the same as a 379 short hood except for the 357 is fiberglass instead of aluminum as found on both 379's reg, and ex hood models. My truck had the Donaldson breathers instead of the Vortox ones. The Vortox units are alot bigger but sit lower on the cowl for some reason. The Vortox AC's also go down to the bottom edge of the cab an most of the trucks I have seen.
Brian
