Old 08-13-2011, 10:37 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Classy Shak
Today I got the front section of the running boards built.
I also added the 359 hood center detail.
~Mike~
Old 08-13-2011, 10:38 AM
Weaver Of Dreams
Ok tonight I installed the light bars under the sleeper. I am basically done with the building from the bumper to the back of the sleeper. I have a few more things like the wings for the sleeper. I have to make the tanks and another side box, and the steps for the rear access, but I need to get the frame done first.
~Mike~
Old 08-13-2011, 10:39 AM
Weaver Of Dreams
Well I guess my mind is made up about the rear suspension, I just ordered the stock rear suspension and the crossmember for it.
~Mike~
Old 08-13-2011, 10:41 AM
Weaver Of Dreams
Well I'm at it again. This time I started with the necessities, can't drive a Peterbilt if the seats are aired up, you'll get a nose bleed sitting that high.
I am using some Wedico seats. They are just the right size and they look better than the Tamiya seats.
I built the Pete center cup holder a while back and got it installed now.
Next I built some scale shocks. The stock Tamiya shocks measure out to be 4-3/8" in scale. I got some 1/4" and some 3/16" brass tubing and made me some proto shocks. the 1/4" = 3.5" scale and the 3/16" = 2-5/8" more to the right size.
However diameter was not the only thing that bugged me. The length of the stock shocks is WAY wrong. Making the mounting locations wrong specially on the front.
I made these so they are the proper size and then i made the proto shock mounts.
~Mike~
Old 08-13-2011, 10:42 AM
Weaver Of Dreams
Howdy All.
Well Today I got the shock for the right side done.
Finished the core for the Air-to-Air.
Then I had to find something else to do so I made brake cans.
I have a big roll of 35 pair wire that I got in my RR layout days. I took a strand of that and pulled the wire out of it to make it pliable. I then took two 1/4" long pieces of .020" brass rod and glued them half way in each end. Then I drilled a hole with a #76 drill in the can and in the frame. I glued the brass rod in both. This gives the hose the flexibility it needs but helps give the connections more strength than if I just glued it to the side of the frame and the can.
Then a turn to the right and the left to check for clearance and movement, and all is good.
~Mike~
Old 08-13-2011, 10:43 AM
Weaver Of Dreams
Hi All..
Wow I got a very cool present in the mail today from a real good friend. I will let him say who he is if he wants.
All I can say is Thank you very much.
These things are so cool..
Thanks Friend!!!
~Mike~
Old 08-13-2011, 10:44 AM
Weaver Of Dreams
Hi All!!
Well I got my package from Lynn (tc1cat) and am glad to add some more of his fine work to my truck.
I sent Lynn a drawing of what I wanted and he made it look exactly like what I had in my head...
I had him make the Pittman arm and a steering arm for the truck.
I told him I wanted it to look like the real thing and that's exactly what I got.
Then I needed a special bumper because of how far forward the steering axle is mounted and again I sent a drawing and he made it perfect.
Thanks Lynn for the good work. It really adds to this build.
I also got a few more parts from RC Dampner.
I got the rearend cross member, the radius rods for the rear suspension, and the tank mounts for either 2 or 4 tanks. I have not made up my mind yet. But either way I have enough.
~Mike~
