Old 08-13-2011, 12:34 PM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Classy Shak
Originally Posted by Straywolf View Post
Wow this is one beautiful rig all the detail just wow i am awestruck so i gotta ask when you do the lights will the dashboard have lighted gauges and such?
Mike
Yes they will be back lit. The turn signal indicators and the high beam indicator will also work.
~Mike~
Old 08-13-2011, 01:25 PM
Straywolf's Avatar
Straywolf Straywolf is offline
Straywolf is on a distinguished road
~Mike~
Sweet i cant wait to see this, would you mind showing us how to back light the dash i have been wanting to do some thing like this someday and i am not sure how to figure it out.
Again excellent work
Mike
Old 08-13-2011, 11:24 PM
Weaver Of Dreams
Mike
Well I have no idea when I will be doing it but here is my idea..
I was thinking of making my own decals of the gauge faces on clear decal paper. Since printers do not print white that means the white numbers on the gauge face will be left clear for the light to come through. Then I will adhere them to a piece of clear overhead projector sheet and cut to size.
Next I will drill the holes in the dash in the appropriate spots and make them just a hair smaller diameter than the gauges I have just made. Then glue the gauges to the dash.
Next I will build a small box for behind the dash and light it with some 2x3 mm LED's. the inside of the box will be covered in aluminum foil to give it a reflective surface. The LED's will be mounted on the underside of the dash facing the box with the aluminum foil thus causing the light going through the gauges to be both uniform and slightly defused so as not to be so overwhelming.
As for the turn and high beam lights I will use the appropriate colored LED's sent threw fiber optics.
~Mike~
Old 08-14-2011, 10:34 AM
Snowman's Avatar
Snowman Snowman is offline
Snowman is on a distinguished road
Good to have you back among us, I missed classy shak
Nick
My Peterbilt build thread:
Old 08-14-2011, 01:59 PM
Straywolf's Avatar
~Mike~
Sounds like you have the right idea about this i was wondering if foil would be reflective enough i was thinking of using something foil tape like the one in this link:
http://www.ecofoil.com/All-Products/...e-Tape-2-x-150
I know you can get this in any hardware store it is a metal tape with a paper backing to peel off and it's already glued, used to do AC work with my dad and we used this type of tape alot,and this tape will polish up pretty good, just a thought.
Mike
Old 08-24-2011, 02:51 PM
bigdogrod bigdogrod is offline
bigdogrod is on a distinguished road
simply amazing build..
Old 08-24-2011, 08:53 PM
Weaver Of Dreams
Originally Posted by CrimsonCorsair View Post
I too was looking to put the steering servo inside my CAT motor. I would be interested in what work you were planning on having Lynn do. I was planning on dropping the oil pan and opening up the hole in the bottom of the motor enough to slip the servo (HiTech 645) inside. I was hoping to replace the oil pan, however the servo will not fit far enough into the motor to allow this. Is this the work you will be having Lynn do for you? You would need to remove the bases where the two motors are joined by screws and then find another method to attach the motor back together again. Even doing this I am not sure the servo will fit far enough into the motor to re-attach the oil pan. I would be very interested in your plans - especially if you have solved this dilemma. Who knows, maybe Lynn will have two motors to modify
Well I sure would like to tell ya but as of right now we have not figured it out completely. From what I can see when I look in the motor I have found servos that will work. Lynn will be removing the tubes that hold the screw for the oil pan and then I will mount the pan by a screw in both the front and rear covers.. Other than that Lynn has to get it in his hands first and then we will discuss the best way to go about the install. I will certainly let ya in on the how to when we get it done. Remember also that I have turned the pan around on my motor so the servo shaft will be going through the hole on the shallow part of the pan.
Thank you Sir...
The suspense is killing me. Steve sent my air cleaners on Monday and the pony express... I mean USPS has not got it here yet...
~Mike~
