Old 08-14-2011, 12:06 PM
Bsorenson79's Avatar
Bsorenson79 Bsorenson79 is offline
Bsorenson79 is on a distinguished road
Default Re: Another MFU question
Originally Posted by CustomRCmodels View Post
this is a fine-tuning for the neutral position of your trim for the horn and 5th wheel operation . This will also effect your engine-shut-down and lights .
Just set it up as descript on page 6 of the manual.
So far I don't remember ever had to mess with it , at least by the radio-systems I use , JR / Futaba and Spektrums it did work right from the get go .
If you get confused with Tamiya's channel descriptions ( since there manuals are written for transmitter stick-mode 4 and here in the US we use mainly stick-mode 2 )
check out this write-up I made a few years back for our tanker-guys
http://customrcmodels.com/Tanks/id92.htm
If I'm not using the servo for the trailer coupler. And I end up using it to control my lift axle. Should I hook up it to the MFU or just run it out of the receiver?
