Looks to me like it operates really nicely. Great work, yet another model I'd like to build in the near future.
I am going to guess you are drawing to much power from the servos and it's "resetting" your speed control. You will need higher voltage battery and/or an additional one to operate the servos, this may alleviate your problem, that would be my guess. Ben |
If your using the BEC on the speed control , it will not put out the needed amps the high torque sevos need . get yourself an external BEC . OTOH , the kitten looks great .
Thanks for the info. If I plug a 6v batteery into the reciever in the batt/bind plug, do you think this will solve it or do I have to buy something else? I tried posting a couple more videos last night but they didn't completly load so they'll be up soon. Nothing to exciting though, just me doing the same thing...lookin like a spode!http://youtu.be/KrTU9iBcgq0
Thanks for the input! I have a 5 cell 6 volt 4200mah hump pack with the reciever plug on it so I will give it a try and see what happens. The cap may be a better solution to my problem though because the screwdrive takes up a lot of space and I don't think there is much room for another battery. I don't understand why the esc on the screwdrive still works when the sabertooth resets? Maybe it is more like a woman... sensitive?
Thanks again for all the help. Reg |
