Old 08-27-2011, 09:00 PM
Default Re: Here Kitty Kitty...
Plug the battery and the servos into the receiver it should be fine and it works that way. The bec will plug in and work the same way but you will be better off with a separate battery. The bec like Castle Creations say 10 amps but it will handle an instant amp draw of that but not a continuous and the continuous rating goes down the higher voltage you put into it. I had a similar issue with my 4WD cat tractor I was only trying to run one high torque 1/4 scale servo and Castle Creations bec would not do it but a good receiver battery would.
The CC BEC 10A Receiver Battery Eliminator by Castle Creations.
FEATURES: Eliminates the need for a receiver and servo battery pack
Draws higher voltage from the motor batteries and drops it to a
voltage level suitable for the receiver and servos
CC BEC receiver battery eliminator
SPECS: Length: 1.2" (30mm)
Width: .6" (15mm)
Height: .4" (10mm)
Weight: .4oz (11g)
Input voltage: 5V to 25.2V (2S to 6S Li Po)
Current output: 12 volts input = 7 amps* continuous, 10 amp peak;
24 volts input = 5 amps* continuous, 7 amp peak
*Ratings are determined with a 5mph airflow on the BEC
Selectable Output: 4.8 - 9.0V via the Castle Link
Default voltage is 5.1V
Old 08-30-2011, 04:07 PM
For any of you Vancouver Island guys that might know, what is the plan for Port this weekend? Are all of you still going to the antique truck show? I think I can probably play for a bit.
I'm franticly painting my "kitty" today. I hate painting...
