Old 08-30-2011, 06:43 PM
CustomRCmodels's Avatar
Default Re: Selecting a New Radio, HELP!!!
Originally Posted by fhhhstix View Post
Willy I will tell you and the others get the digital trims out of your head you don't even need the trim buttons to work the MFU!!!!!!!! Say it with me dual rate yes that is right say it a gain dual rate. All you are doing by moving the trim is giving the stick more throw in that direction. Now get to know your radio and you will find the dual rate switches. Set rate one to 100% and rate two to the highest setting 125-150%. Take the light and flasher function for this example with the trim you have to move the trim one way to activate lights or the other way for flashers. With the flip of the dual rate switch you have the choice to do either one because you have just added extra throw to the stick in both direction and with the flip of a switch you are back to normal. All I am saying here is make it simple for yourself and forget about the digital trims they mean nothing to the MFU.
Travis
Yes you are correct Travis ,
I been using this way of doing it on our MF-tanks .
But most transmitters allow only for 2 axis dual-rates not for all 4 ,
or I am missing here something ?
(Wild)-Willy
CustomRCmodels
