The ESC is the kit one, or what comes with it stock?
Sounds to me like it could be a low voltage detection issue in the ESC, of which being an OE ESC there will be no adjustment as it's only made for a 2S. So, you may be able to get Losi to replace it with a call to them, or look at replacing it with an aftermarket ESC. Another thing you can check, I'm not familier with that charger, but on mine I can set the max MAH, which I had done for a RX pack and forgot to set it back for running packs. So even showing fully charged they only lasted a few minutes.
Call me Thor, it's short for Thorsteenster. In VA? Check out To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
