Well I finally got enough fabbing plastic/styrene done to justify a thread of this build. I'm really going all out on this build, gonna try to get every detail as close to the movie truck as possible. First I had to raise the cowl panel up, then chop the A-pillars down and angle them foward. Also had to make all new front window channels to get the vintage look of the old Petes.
![]() ![]() The roof had to be sectioned a bit and new cab corners made out of styrene. I wanted the roof to be overlaped on the corners and in the middle just like the old trucks. So I had to make a center support for the panels to lay on. Also had to drill and peg all the but glue joints so they would be stronger but very time consuming ![]() Got a bunch of putty work done on the roof and fill in some minor areas. Goind to cover the entire body w/ .010 sheet styrene to give it that extra realism of overlapped panels. ![]() ![]() ![]() ![]() ![]() ![]() ![]() I accidently ordered a reefer tag axle ![]() ![]() ![]() Cut the bumper way down, haven't got to make the railroad tie bumper for it yet. ![]() ![]() Also got Steve making me some 5 and 6 slot wheels for it can't wait to see them Steve! ![]() Last edited by DuelTruckDriver; 09-19-2011 at 08:32 AM. |
WOW
![]() Nice work Marty,I will be following this one for sure!
Troy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
![]() ![]() ![]() dave |
Wow, very cool! I'll be watching this one! You already are off to a great start.
Nathan |
Hey thanks for the compliments Troy and Nathan.
So far my plans are for it to have a fully working butterfly hood, opening doors, working headlights, and turn signals. |
Looks great so far!!! I really appreciate your attention to detail on the cab.
Brian |
Brads classic trucks in NC has the original movie truck in his personal collection. There might be pics on the website.
Looking sweat! Can't wait to see more.
Any new pics yet im ithcing to see more
Dave |
The cab is looking good Marty. I want to make a 281 one of these days so I will be watching this one.
~Mike~ |
Nice build. Just curious, why the tag axle?
Not yet Dave, I've been working pretty much all day yesterday and today on getting the doors made up. Next I'm gotta get the new cab mounts done so, I can start on the fenders. I hope to have new pics up this weekend.
![]() Thanks Claus, I'm just making the Pete movie accurate no other reason. As the one from the film has it too. I was kinda bothered by the idea at first, ![]() ![]() |
nice fab work on the cab - nice and precise .....
Just curious, where in the movie did it show the truck having a tag axle, I don't remember that but it has been a loooonng time since I watched it.
I read the same thing about the real movie truck having a tag axle also. Not sure where in the movie it's readily visible, but I would have still made it a twin screw drive, myself.
Nathan |
Thanks Izzy
Claus and Nathan, there are 2 spot in the movie that I've seen, there may be more if you really search. First, shot I seen was at the ladys gas/snake station. Where Dennis gets in the phone booth the truck starts up and stars to roll. It shows the undercarriage just enough to see there isn't a rear drive axle if you pause it and slow motion it. Second, shot is after the truck has went off the cliff. It shows the wreckage of the truck ontop of the car you can clearly see the tag axle there. Also, when you get to see close side shots of the truck you can see that the rear axle has a grease hub cover, instead of the drive axle nuts holding the axle into the hub. oztruck, man I hope my tanker turns out as awesome as yours ![]() >Marty< Last edited by DuelTruckDriver; 09-08-2011 at 08:40 AM. |
Hey guys, finally got a new update for ya on DUEL
![]() ![]() ![]() ![]() Heres a pic of one of the sets of hinges. ![]() Got the belt line applied around the roof used some half round rod. Man, of all the styrene I've worked with this was a real pain in the a$$ to get perfectly straight around the top. ![]() ![]() Heres my 2nd set of doors they are gonna be overlaped of .040 for the inner which will fit flush inside of the cab door cut outs. And .020 for the outer skin which will over lap the outside of the cab. ![]() ![]() Incase you guys were wondering about the green painters tape on several spots of the frame. Thats actually were I'm gonna cut the frame down too. But, I'm gonna wait and do that when I get everything mocked up. I made the cab mounts out of angle styrene doubled up for strength. And then it they were pegged glued to cab. Also backed all the glue joints w/ .040 sheet cut to fit patterns and made a partial fire wall. Since the doors are gonna open I was afraid of the structural integerity of the cab. I know its way over kill but I just couldn't help myself ![]() ![]() ![]() ![]() Heres what I had to do to the cab floor, cut the sides down and, use alum. strip to bolt under the floor so that the cab would be at the correct height. And also to bolt the cab to the floor with. ![]() ![]() ![]() This shot here you can see that I used some strip styrene and glued to the underside of the cowl panel for the top and sides of the hood to rest on. ![]() Some shots of the cab on the frame. The cab may half to be moved foward or back. Depending on when I get the fenders mounted to get the right length of the hood. ![]() ![]() ![]() >Marty<
"You play meat?" Last edited by DuelTruckDriver; 09-18-2011 at 09:59 PM. |
More pics of the tag axle installed it turned out really good
![]() ![]() ![]() ![]() I did move the front axle foward and made some shims to raise the front end back up. When you move the axle foward it lowers the front end about 2-3mm. ![]() ![]() Got the front grill sketched up, gonna be a good bit of work involved in making it also. Notice how much taller the old grills are compared to the more modern ones. One reason was that the front frame horns were angle cut so the grill pretty much all the way down to the bottom of frame channel. ![]() >Marty<
"You play meat?" |
