Old 08-28-2010, 07:20 PM
Default Re: lipo trouble
I just meant the scale doesn't matter as in the battery doesn't care if it's in a 1/18 or a 1/10 RC, it's still a 20C XXMAH.
The 1/10 will for sure pull more but the ratings on that battery should be plenty capable, the wiring looks pretty suspect though. Looks like BEC/servo gauge wire.
Call me Thor, it's short for Thorsteenster.
In VA? Check out
Old 08-28-2010, 09:08 PM
Hay Thor no problem discusing this stuff to find a solution is what this is all about.
Old 08-28-2010, 09:20 PM
CorbettTrailers's Avatar
CorbettTrailers CorbettTrailers is offline
CorbettTrailers is on a distinguished road
Exactly. The SC10 Short Course Truck I have has a brushless system and I run a 3200 2S 25C battery. I also have low voltage shut-off on my ESC. If I run it with voltage shut-off, turned off, (for NIMH or NICD batteries) it won't run. I have to run it with the voltage shut-off, Turned ON, Which is made for Lipo batteries. In my opinion, it's going to be your ESC is not programmable for the voltage shut-off option, ON/OFF. My 3200 Lipo will last about 25 minutes in my truck. Not sure if I helped but if you can spare the extra $$ for a Brushless/Brushed ESC with voltage shut-off options, it'd prolly be worth it. I've over charged my Lipo and had it way too low and it's 6 months old and still works perfect.
ECMT Members: Join your Group. Go to your username in the top right corner of the page and click on it. When your profile opens go down to group memberships, Click on East Coast Mini Truckers, The social group will open and scroll down And in the middle it you will see "Join Group" Click on it and then confirm that you REALLY wanna join.
[SIZE="2"]
