Old 10-05-2011, 10:55 AM
Default Re: Custom lowboy 'kit' parts needed...
This isn't a 'buy' post, more of a 'I need some advice on who makes (or ~can~ make) this stuff' thread.
Then again, judgement is up to Admin... right? If I've worded the post improperly, let me know and I'll amend/alter it.
I'd like to add that I'd like some advice on compatible 'beefy/military' rims and tires for the King Hauler kit. Ones that do not entail hacking either rims or tires. I don't mind adding spacers in between rim halves, but I do mind having to slit a rim around its diameter to widen it without having a spacer to fit in to widen it properly.
WhiteWolf
Old 10-05-2011, 07:35 PM
JensR JensR is offline
Not sure what level of detail you want and what degree of manufacturing you can do, but...
Smaller than Tamiya wheels are offered by several companies, but the easiest to get in North America might be the Wedico tires. They are 1:16 and hence just that that bit smaller to look good on a lowloader (IMO).
Axles can be modified to Tamiya width from the tire-matching Wedico axles or scratchbuilt completely.
If you want steered axles, again there are some manufacturers out there. I know of SchulzTec in Germany. But they come at a price.
OTOH, scratchbuilding a steered trailer axle is also not that difficult.
Main frame rails can be made from aluminium profile at your local DIY store.
Swing out wideners are sold by Veroma and SchulzTec.
As for heavy duty rims for the tractor unit, have you checked the RC4WD ones?
