Old 10-28-2011, 03:40 PM
modelman modelman is offline
Default Re: Tournarocker Diversion Build
Very nice work steve-I didn't realize these motors were this small. This is the same problem I had -finding small dia. motors with enough torque but I had 1.35" dia. to work with. Have you looked at "robotmarketplace". They have some small dia. motors but are not going to be high in torque rating. The "beetle-62:1 is .86"dia. and 300RPM but not much torque. Hope you find something, I'm anxious to see this work!
Old 10-28-2011, 05:58 PM
JensR JensR is offline
Some things to consider:
Angle the whole assembly slighty (or a lot) upwards. This might offer a bit of space.
Use motors with non-concentric (eccentric) output shafts and arrange them so that they use the space better. (There's quite a bit of empty space between the motors now, so the motor housings could be rotated inwards with eccentric shafts.)
RB35 motors, replaced with 380/400 sized motors are a force to be reckoned with and have eccentric output shafts.
Como-Drill also makes some nice gear motors like that.
Old 10-28-2011, 06:42 PM
JAMMER JAMMER is offline
Looks real good Steve we will get to see it work in a few weeks. The evacuator is almost done and maybe I,ll get the loader done also. Ed
Old 10-28-2011, 08:32 PM
I've been looking into that type of motor you described. Pittman here in the states makes some like that. I haven't attached the drive to the toy yet so there is some room to angle about there but only 3''wide to work with. Most of the more powerful motors are getting close to 1.5''w.
Here is one that I'm considering:http://www.anaheimautomation.com/pro...tID=103&cID=46
The model R19 is looking pretty good but looks like a special order in that ratio. I may go with the R27 but may need to overdrive the secondary reduction some. My final output speed is: 35RPM but would like to see 50rpm so it won't be so boring on a long haul.
