Old 11-01-2011, 08:45 PM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
Default Re: Day cab dump truck
Great looking truck man! Is the charging jack in the front bumper? Is the port something you buy or build? I have never seen tis done before/well with the exception of a charging jack on a remote, but on a truck its a new one for me..How does the speed control for the dupm wire in? I will be building a dump trailer for my dodge, but I cant wrap my head around how the wiring will go??
Old 11-01-2011, 09:20 PM
Originally Posted by cabrover View Post
Looking great Travis, cant wait to see this one done!!!
Tim
Thanks Tim I have some ideas for modding the cab into something a little different so it might be a bit before I have another update.
The charging port is a Deans connector wired into the off side of the power switch so it is just like plugging the charger into battery but you don't have to remove the battery to charge it. The ESC for the dump is wired in parallel with the drive ESC so it gets shut off with the power switch as well. The ESC for the dump is from The Robot Market Place (Click here to see the ESC) and it has solder spots for limit switches to limit up and down travel and is perfect for the screw drives. For a dump trailer I like to build tool boxes under the bed for the ESC and battery so the trailer is self contained and only needs a servo lead to the trailer to control the dump allowing it to be controlled by multiple trucks easily.
Thanks to all for looking and the comments.
Old 02-19-2012, 07:32 PM
Well I finally got busy today and painted the truck so now I have to let it dry and I can assemble it and it will be done.
Thanks for looking.
