Old 11-07-2011, 02:16 AM
mikenredding mikenredding is offline
mikenredding is on a distinguished road
Default Re: Bruder Liebherr loader build
I wonder if your screw drives could be made to be used for the turning rams.
Old 11-07-2011, 06:48 AM
pumptech's Avatar
pumptech pumptech is offline
Hey Mike ,I thought about that,was leaning more on using a high torque servo with linkages.Have played around with sliming the screwdrives down,leaving off the 1/2 SST ,using 3/8 and 1/4 ,with a smaller auger bit that fits in the 1/4.Then of course have to keep space in mind for the battery/electrical gear.
Old 11-07-2011, 08:46 PM
pumptech's Avatar
Hey guys this post was mainly to check pic size,looks bigger on my end.
Little progress tonight,got a couple of the boom arms cut out so far,its a slow go.
Uploaded with ImageShack.us
Old 11-12-2011, 09:27 PM
pumptech's Avatar
Little progress on the front portion,the boom looks a little rough right now,just tacked together,wanted to get the screwdrives made ,check things before i weld it out,got the bucket linkage made, have to tack down,hope to have the boom/bucket working soon..
http://
http://
http://
http://
Old 11-21-2011, 10:27 PM
pumptech's Avatar
Well,I had a little setback on the boom, wasn't going to reach max hieght, the way I was going with it,with the servo incased in the front portion,had to come up with plan B ,reverse it ,put the servo in the boom,have the new boom tacked together,got the rams made,seems to work much better now ,has good lifting power with just the one ram,will be using two though,now onto getting the bucket going.
Have a few pics and vid.
http://
http://www.youtube.com/watch?v=ds87p...el_video_title
Old 12-10-2011, 10:49 PM
pumptech's Avatar
Well,little update on the loader,been working on the swivel for the middle,rear section,now on to mounting the rear axle.Forgot to take a pic of the bottom of the model,but have metal tied in to the bottom,will get that pic on the next post.
http://
http://
Old 12-13-2011, 07:15 PM
pumptech's Avatar
Well , getting a little futher with the loader,got the rear axle mounted up,thought about using one servo with a linkage,thought about it some more,decided to try screwdrives,works well,took apart one of the servo's,desoldered wires on the motor,changed postions of wires,soldered back,to get the push/pull for the screwdrives.
I know my metal work looks pretty bad right now,just getting it all mocked up/tacked together,once I have it mocked up,going to take it all back apart and finish welding everything up,grinding down all smooth.
Have a few more pics and vid.
Thanks for looking
http://www.youtube.com/watch?v=xfB5a...el_video_title
