Old 11-11-2011, 09:39 PM
Msmaddie's Avatar
Msmaddie Msmaddie is offline
Little miss fabricator
Msmaddie is on a distinguished road
Default Re: Help with a bandsaw
Im sorry if some has said this already. I bought a 9 inch Ryobi bandsaw last night. The mastercraft I bought had a horrible selection for blades. Anyway I put a 18tpi blade on it. Cuts through aluminum just beautifully. Nice and straight. Was a little rough but a few seconds with the dremel it was smoothed right out.
Hope this helps.
Old 11-15-2011, 07:19 PM
FreddyGearDrive's Avatar
FreddyGearDrive FreddyGearDrive is offline
Admin RIP FGD 2-12-59/12-19-11
FreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the rough
Just a stupid question,but why do you guys use a band saw?
A scroll saw is way better for what we do.
W/a scroll you can make long cuts & also cut out little parts.
The only difference is you can walk away from a band while it cuts,but best hope it cuts where it's spoda.
Just a suggestion,try coating the blade with bee's wax.it'll cut down on the side tracking. Although,you have to coat it every 30 seconds or so.But it makes a HUGE difference in how straight the blade tracks.
Just what I've learned since being in this hobby.
FGD
Old 11-16-2011, 09:04 AM
siuvinson siuvinson is offline
siuvinson is on a distinguished road
FGD
fgd what blades do you like to use on your scroll saw? And is your saw variable speed, and if so what speed do you use when cutting?
Old 11-25-2011, 12:19 AM
For thick metal I use a course blade(low #of teeth per inch),for thin a fine or high # per inch. & variable speed really helps.
Two things to remember when cutting a metal w/a scroll is never force feed it & don't let the blade get hot.
FGD
