Old 11-20-2011, 10:25 PM
ihbuilder's Avatar
Default Re: Mack M75SX
" I think the back of your pickup will be too small for your 990 to maneuver, you'll need a track hoe instead. "
Joe , Thats on the drawing board too I'm going to keep the rears , too much time and sweat went into them . I had a slipping pinion in the fwd axle only cause some dummy put the shims on the wrong side . I have to set my esc with the radio and maybe tweek it a little . The problem is no smooth opperation . the biggest PITA is the front tires rolling off the rims loaded (40 -50 Lbs tare weight ) . I going to try filling a set with silicone to see if that helps . Then I got to get these cylinders made .
