Well,I had a little setback on the boom, wasn't going to reach max hieght, the way I was going with it,with the servo incased in the front portion,had to come up with plan B ,reverse it ,put the servo in the boom,have the new boom tacked together,got the rams made,seems to work much better now ,has good lifting power with just the one ram,will be using two though,now onto getting the bucket going.
![]() Have a few pics and vid. http:// ![]() ![]() http://www.youtube.com/watch?v=ds87p...el_video_title
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Well,little update on the loader,been working on the swivel for the middle,rear section,now on to mounting the rear axle.Forgot to take a pic of the bottom of the model,but have metal tied in to the bottom,will get that pic on the next post.
http:// ![]() ![]() ![]() http:// ![]() ![]()
Well , getting a little futher with the loader,got the rear axle mounted up,thought about using one servo with a linkage,thought about it some more,decided to try screwdrives,works well,took apart one of the servo's,desoldered wires on the motor,changed postions of wires,soldered back,to get the push/pull for the screwdrives.
I know my metal work looks pretty bad right now,just getting it all mocked up/tacked together,once I have it mocked up,going to take it all back apart and finish welding everything up,grinding down all smooth. Have a few more pics and vid. Thanks for looking ![]() ![]() ![]() http://www.youtube.com/watch?v=xfB5a...el_video_title
looking good .........keep it comming
Thanks chaseracer,still have a long way to go with it,thanks again.
