Old 11-22-2011, 01:08 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Classy Shak
Originally Posted by Brian in PA View Post
Mike, you should consider the 3 speed just for the coolness of it. You have the room. I have a 55 turn motor in my dump I'm currently building and I added a 3:1 from Integy. Travis turned me on to this. It works really good and is like 20 bucks!
Brian
Brian unless I cut a hole in the floor of the sleeper and put the motor and 3 spd there, I don't have the room. the floor on my cab is flat. and about 1/4" above the frame rails.
Mike "DREAMWEAVER" Johnson
Old 11-22-2011, 06:44 AM
Brian in PA's Avatar
I'd rather be truckin'
Thats what I meant. You could easily hide the drive line in the sleeper. Your cab is detailed are you doing this to the sleeper also?
Brian
Old 11-23-2011, 01:28 AM
Weaver Of Dreams
Brian
Hadn't planned on it, but ya never know
The main thing I am asking is what motor. I have no idea what 540, 775 ect means.
Here is a link to the place where Rick said he got the motor and the gear box for the yellow zonker but they don't have the combo that he got any more.. But these are the gear boxes I was thinking about. Rick said he had a 25:1 in the zonker.. http://banebots.com/c/PLANETARY
Old 11-26-2011, 02:56 PM
Weaver Of Dreams
I could use some help here guys... If you have a link to a site where I can find motors and gearboxes please post them.
Old 11-26-2011, 11:00 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
540 cans are the stock size the Tamiya kits come with. Plain silver can motor cheap and you can get them everywhere. I like the tamiya three speed with gear reduction/low count pinion. I ran mine with stock can and pinion with 4:1 on 3S lipo and was still pretty quick. I limited throttle on my radio a bit in fwd and lot for reverse.
Old 11-27-2011, 02:00 AM
Weaver Of Dreams
Thanks.. No room for the 3 spd. I built the truck planning on using a motor and gearbox that Rick (Roque) used but the link he sent me a long time ago don't work anymore.
I got it all figured out thanks to TC... I will be using a 540/55t with the RC4WD Disruptor. That should get me closer to the speeds I want.
