Old 11-26-2011, 07:18 PM
Trucker47's Avatar
Trucker47 Trucker47 is offline
Trucker47 is on a distinguished road
Default Re: Let The Build Begin!
Okay I think I might try that out once I get my pump and motor using these http://www.robotmarketplace.com/prod...ingertech.html
Yea if I can get some spare time and if it works out ill let you know.
I used some motor oil that we had in the shop but that's about it. But I got some brass today so ill start on some new cylinders. On my existing cylinder there is quite a bit or resistance but i guess ill just need the pump to test and see if it is to little or to much resistance.
Thanks!
Old 11-26-2011, 08:15 PM
ihbuilder's Avatar
motor oil works too . there should be some resistance but you should not have to work up a sweat to move the ram in or out with a vise grip locking pliers . there's a formula or chart for figuring your o-ring grooves I'll have to look it up . I think it's in the machinery hand book . do you have 1 or access to 1 ?
