Old 09-01-2010, 12:32 AM
Default Re: Powered lift axle??
Hmm, never heard of a driven lift axle. Interesting. Do you have any photos of the truck that would have this set-up? Sounds like it would have a disconnect inside the axle, possibly the in the differential. Air actuated perhaps. Not sure how you would replicate that in a scale truck. Sounds cool though.
Old 09-01-2010, 04:08 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Dig unit for crawling maybe?
Old 09-01-2010, 08:12 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Wish I had pics! Just saw it going down the highway. Actually a strange truck. Straight truck with a full size sleeper, kind of short box on it, with the rear axle a lift axle with power?? Stranger part was it did not have any name on it as far as who owned it.
I am always on the lookout for different looking straight trucks!
Thanks for the ideas on making one. Just have to start thinking outside of the box on this one.
Old 09-01-2010, 08:24 AM
ihbuilder's Avatar
sounds like you want to be able to disconnect it when in up position . some kind of clutch between the drive shaft and axle . this will be interesting
Old 09-01-2010, 08:37 AM
That would probably be a little difficult to mount on the axle.
Here's a pretty straight forward driveshaft disconnect. Use male Stampede drive shafts on the rearmost pass through axle and on the lift axle, then a female to go over the two to slide back and forth, joining the two males end engaging/disengaging drive. I did this with Revo shafts a few years back, into one of the male ends I threaded a bolt with the head rounded off to keep the female slider in place while disengaged and I used an old steering knuckle around the slider attached to a servo to move it. You'll have to figure out how to keep the knuckle in place laterally on the slider while allowing it to spin.
Call me Thor, it's short for Thorsteenster.
In VA? Check out
