Old 12-09-2011, 12:05 PM
pigeonfarmboy's Avatar
Default Re: PFB Tri-Axle King Hauler
Should have known to look on his channel. Love his vids. That thing would probably be pretty simple to make too. Much easier to hide a winch than a screwdrive lift.
Let me put on my lab coat here and talk some theory on the physics with the model:
If the weight of the 850D excavator is supported entirely by the trailer/jeep, you would need to add more weight to the truck to efficiently pull the load correct? Or add a weight box to the extended neck?
Old 12-09-2011, 12:56 PM
ihbuilder's Avatar
the idea is to uniformly distribute the weight on all axles including the tractor . placement of the 5th wheel is crucial ( hence the sliding 5th wheel plate ) Here in PA ( last time I moved a permit load ) , we're alowed 20,000# per axle at a given distance appart ( I gotta find my PA DOT book ) . If you look at the position of the 5th wheels on the aspen set up ,it transfers enough weight to the tractor .
Old 01-06-2012, 10:24 PM
hvy 1ton hvy 1ton is offline
hvy 1ton is on a distinguished road
The winch isn't a required bit. The guys up north use winches to pull the trailer up the ramps to save the driveline in less than ideal conditions.
Old 01-09-2012, 08:42 PM
kcjeepn's Avatar
kcjeepn kcjeepn is offline
kcjeepn is on a distinguished road
Very nice rig!!!!!
