Old 12-12-2011, 10:09 PM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
Default Re: Pete 367 in brass
Timmy, what type of welder are you using on the bed?
Old 12-12-2011, 11:03 PM
Timmy Timmy is offline
Timmy is on a distinguished road
I'm using a 115 volt mig with a 25/75 mix of argon to Co2
Old 12-15-2011, 08:54 PM
So I've decided since I have to build he roof again anyway, I might as well take crawler07's advise, and build a wooden buck. The buck I've made is a simple one, and I built it out of 1/2 inch balsa. I don't intend to hammer against the form, just use it as my guide. I've annealed my brass before starting so that I don't have to heat against the wood either, not a good idea with balsa, my wife would kill me if I set fire too it. Here's some shots of the basic wood form
It's a nice dock isn't it
Cut to general shape
Now this picture shows the height of the buck, the buck it self is 1.3cm tall (when I scale I use centimeters and millimeters, one cause I'm Canadian, and two it's easier then figuring out thousandths) this happens to be the exact scale height of the roof after it slips onto the cab, so as I shape the buck, I will have to keep this in mind
I'll post more pics as I go
Old 12-16-2011, 09:48 AM
I finished the final shaping and started building my new roof panel last night
It looks tall, but the dimensions are correct, and the roof will slide down slightly from here
The shape looks very good in the side profile
This is the beginning of the new skin
I may build the roof in 4 pieces just to ease the metal forming, it will cause more work finishing the solder joints and smoothing it, but sometimes the longer route is the easiest. And if all else fails, I can smooth the buck even farther and stain it, a nice wooden roof for this Pete lol
Hope you enjoy
