Old 12-13-2011, 07:42 AM
Snowman's Avatar
Snowman Snowman is offline
Default Re: Nick's 379 build
Originally Posted by sneaky-pete View Post
Wow Nick,
That truck is looking better with each update!
Keep the picks coming....your on a roll.
Thanks Troy! Appreciate it. I hope to have more to show soon.
Wow, it's looking really good, Nick! I'm guessing if both your inner LEDs do not turn on, then you must have something else going on. Hard to believe you'd break the leads or wires on both inner LEDs, don't you think? Maybe an MFU problem? Or whatever lighting kit you are using.
Keep it up! This will be right up there with Brain's Pete when done.
Thanks Nathan, if it's half as good as Brian's I'll be extremely happy.
The LEDs are wired in pairs in series, so it only takes one to be faulty or a break in one wire for neither to work. It's hardly surprising, they are crammed into those headlight housings. I've eliminated the mfu as other lights work in all the outputs. So I'm gonna have to try and isolate the fault with the led pair. It might mean removing the heatshrink where I've cut and re-soldered the LEDs
Thanks for all the comments guys!
Nick
My Peterbilt build thread:
