Thanks for the compliments guys,
The sub assemblies will be pinned or just a tight fit. The swing bearing will be glued into the house once the metal work is finished as a c-clip holds it to the gear assembly on the track frame. Most of the body will just lift off to access the guts when needed and I plan to hinge the engine cover for battery changes. I will leave enough space near the side cut outs to run a cooling fan if needed as well. Everything is TIG welded Chris. Thanks for checking out my progress! Oh yeah, The shop is nice and warm Rob, I'm just non-union ![]() Reg |
I was able to put in another couple hours today and finally got to weld the cab together. I haven't decided whether I will cut out the windows or just paint them black. There is a lot of small cut outs to make so I'm leaning toward painting them on.
