Go Back   RC Truck and Construction > RC Truck's General Discussion. > Get it out of your system! HERE!
Get it out of your system! HERE! You have a gripe,bone to pick, Tamiya vs Wedico or just have to let it out! THIS IS THE ONLY PLACE TO DO IT!
Old 09-03-2010, 12:34 AM
Default Re: I hate Tamiya three speeds
I have trucks with literally hundreds of miles on them in gruelling conditions and they shift perfectly till this day. I use the stock servos that come with the radio and have never changed a servo either.
I chuck that "servo saver" that comes with the trk kit and use the servo horn that comes with the servo, shortening it to what the servo saver device would be. I use the ball and plastic socket head on the servo and drill thru the plastic on the other end to screw the bolt into the locking collar on trans. That way the shift rod can't twist in opposite directions like with ball/sockets on both ends- messing with the necessary distance between shifts. That could be some of your trouble. Proper radio settings would be the other side of it.
Old 09-03-2010, 12:08 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Do you have a pic of this? I have considered doing this because mine seems to flop all over the place.
