Sound Systems tech This section is dedicated to the sound systems for our models. Tamiya MFU, Servonaut, etc. |
Hi Sally, thank you for the reply
had a play today i double checked all plugs on mfu and rx • The Throttle (J5) on the MFU is plugged into the THRO port on the receiver. • The Steering (J4) on the MFU is plugged into the AILE port on the receiver. • The Support Legs (J6) on the MFU is plugged into the ELEV port on the receiver. • The Shift (J7) on the MFU is plugged into the RUDD port on the receiver. and all this right and 5th Wheel servo is pluged into GEAR the TX is set up how you have said MFU control box is set in the middle position. with all this in place when i switch truck on i get steering, gears and 5th wheel, no sound, throttle, lights of any kind. my RX is the AR6200 i have'nt calibrated the MFU i have tried thank you again for all the help Andy |
i had trouble with my spektrum dx7 and my lhs guy set the trim level end points differently and now everything works fine ..i have no idea what that means but thats what he did hope this helps
This seems to be a problem with a lot of people, I read everywhere that yes you can make the dx6i work with MFU but nobody has given an answer (Correct answer that is) about the right D/R and end point %'s , so if you have a radio (in front of you) and your truck is working with MFU and DX6i or a 7ch radio please post your setup and D/R specs. Thank you.
