Go Back   RC Truck and Construction > RC Truck's Vehicles Picture Gallery > 1:1 Your Semi's,Trucks and Equipment
1:1 Your Semi's,Trucks and Equipment Here is a spot to share your 1:1 that you drive and or operate.
Old 01-07-2012, 05:09 PM
Default Re: Diesel Demond's work ride
Originally Posted by Diesel Demond View Post
that jake kicks on so fast and drops the rpms right now
That's the way you want it to work! especially trying to get out of the basement in really soft ground.
If you don't have a Jake, shifting @11-1200 works very well too in low range.
I've never heard the term triple countershaft, is that a reference to Fuller transmissions?
Old 01-07-2012, 05:57 PM
Joe the old 5 speed mack I had had 3 counter shafts in it , whereas the eaton/fuller has 2 . The eaton/fuller is a charm to shift compaired to the mack . I started on that mack 5 speed and it's not that bad ,you get use to it . That old mack had a million on it before she went down and dad desided to scrap it .
Cory , your brap is too long and too soft
