Old 09-04-2010, 12:58 AM
Default Re: *gear reduction unit
Originally Posted by CustomRCmodels View Post
did you forget the ratio between motor and the transmission ?
since I wanted to asked you about that ….
I sure did! Sometimes it's the simplest things. You know, I looked up the ratios of the trans and the axles, but forgot about the pinion and spur gears! D'oh. The Wedico AWD 3 speed has a 24 tooth spur gear and it comes with a 14 tooth brass pinion gear. The motor however comes with a 13 and 12 tooth plastic pinion gear. The motor mount is not adjustable on the Wedico 3 speed, so I'm betting they want you to use the brass pinion that comes with the trans. That gives me a missing ratio, which I failed to factor into my calculations, of 1.71. I also have the belt drive reduction that I can't count, without pulling the plate off the trans. Gonna have to do that too!
