Old 01-21-2012, 10:33 PM
1985 kenworth's Avatar
Default Re: HELP!!!!!!
i'm not sure if you know but when you put install the mfu you have to set it up after you plug everything in and make sure the battery is fully charged in the truck and the radio also if your radio has the manual adjust trims make sure they are all centered if one is off even a slight notch it could be trying to do another function..hope that helps
