Old 01-28-2012, 10:01 PM
Default Re: Leimbach pump motor options?
that motor seems to be working better then I experienced with mine. I wounder if my pump is out of wack.
Old 01-28-2012, 10:35 PM
SmallHaul's Avatar
Great video. Seems like you found a winner there. Amp draw seems very reasonable!
Thanks!
Well done Scott.
My 922 is the only one I ever put a guage on & I set the press to 15bar (210psi).
The older two hoes, the press could have been higher, I had an amp meter wired in thru the plug... cyls moving - 1.1, no movement - 2.1amp.
Your due dillengence has paid off & benifited all of us. Thank you.
You are welcome Joe. The info you gave me on the rpm to shoot for is what made me try the rc4wd 80T so, thank you too.
You might not have been feeding the voltage and load that the motor operates at the most efficiently. I started out by feeding the motor 7.2 volts and when the cylinder speed wasn't fast enough I kept raising the voltage in small amounts until I found the most speed, least pressure & least current draw... The sweet spot for this motor, pump & fluid was around 8.3 volts, .5 amps and about 190psi.
Scott
"No load is too Small"
Old 01-29-2012, 12:29 PM
I tested with 12v direct to the motor. I might try 6 cell battery. I might ask are u running a second lower voltage battery or are using the esc to lower the voltage? my down pump in the excavator that is tether to a 12v dc source. I have no need to run an esc on the pump.
Old 01-29-2012, 01:06 PM
SmallHaul's Avatar
I am using the stock 12v nmih pack and a tamiya esc to limit the voltage to the pump. I have it setup so that the maximum voltage out of the esc is about 8.3 volts (tricked the esc programing into thinking full throttle isn't 100%) that way the pump is always running at the best rpm when any of the hydraulic sticks are at full throw.
Scott
