May I ask why you are going for an axial piston motor and not radial?
Axial machines typically have considerably higher RPMs than radial ones for a given power and hence lower torque on the shaft - are you using a gear between motor and chain wheel? |
Yeah I'm using a reduction gear box like in the real final drive.
great work so far . I'll be watching the hyd. motor build
Just a little update:
The axial piston motor now has one piston. ![]() ![]() It does look wonky but that's because it's right on the end of it. |
Rebekah , you are a genius
