Old 01-31-2012, 07:48 PM
gun's Avatar
gun gun is offline
HillBilly Home Boyeee. WAZZZUP!
gun is on a distinguished road
Default Re: Aeromax Daycab Dump 6x6
looking good Rod ! I have a question did u put the tlt in up side down on your truck or did i put mine in wrong ?
SHANE... Member of the Central Plains Mini Truckers..
Old 01-31-2012, 08:00 PM
All 5 of mine are in the same way as Rods. The way the holes are in the axles it is the easiest way to install them. However if you want to use the servo mount and have the servo on the axle the mounts should go up. But then again you are backwards GUN.
Travis
Old 01-31-2012, 10:09 PM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
I may flip the axle, we'll see where i mount the steering servo. Depends on where I put my transfer case shifting servo... hopefully I'll get the driveline in this weekend...
Travis has been a huge help on this project thus far... with the axle, installation of, driveshafts, etc... tks sir!
East Coast Mini Truckers
Old 02-01-2012, 06:38 AM
gun's Avatar
gun gun is offline
Travis
If you flip the axle over will it spin the wrong direction or am I missing something ?
Old 02-01-2012, 06:54 AM
yep , a few bricks Shane you just adjust your rear axles accordingly
looks good Rod good to see you building again
Old 02-04-2012, 10:02 AM
gun's Avatar
gun gun is offline
THAT IS EASY ENOUGH ! SORRY TO POST JACK YOU ROD BUT MY SIMPLE WAY OF THINKING HAD ME ON THE WRONG PATH
