Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > S n P Customs
S n P Customs Custom builds, Custom parts, Custom metal polishing...
Old 02-05-2012, 10:40 PM
1985 kenworth's Avatar
Question Re: Custom fenders
ok i have a kinghauler and a globeliner the suspension is stock but the wheelbases on them are longer than the standard box stock trucks are you sure the wheelbase would be an issue i thought the axle spread would be the a problem ..i am talking about someone building the mounts to mount them on the trucks
Old 02-06-2012, 02:01 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Custom fenders
Wheel base would not be an issue unless you changed the drive wheel spacing, which you can't do if using a stock suspension. However if you were to use the air ride kit that Russ sells then you could change that spread. However if you were to change the drive spread then the fenders would not fit anyway.
Mike "DREAMWEAVER" Johnson
