Hi there guys sort of new to this section but I have been a closet builder for awhile now I did not see the since on showing something many have done but Scott "Small Haul" said I needed to get my builds up.. I did a bruder dozer 2 years ago and it is on the bench for a rework putting new motors and sabertooth esc and better servos but I am working on the forks for my delta today as i made a mistake and made the first ones all from brass so they are too heavy to use so the new ones will be made the same but from brass and plastic..
So here is the skid with the brass forks.. ![]() And here is the start of the new one.. ![]() Here is my play area too I will be changing it next weekend so we can use the sand master and crum rubber but we will still have the loading yard too.. ![]() ![]() ![]() I also will be doing a thread in my wheeled cat skid and I am looking at the mini cat payloader I think I can make that rc.. More to come on that.. That is it for now but it will be done today so check back..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
That looks nice, but the Wilson looks really nice with paint
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
Wow? What scale?
1/14 Ok so took a extra bucket and cut off the hook ups off the bucket and fied them to the back of the forks mounting plate. ![]() ![]() ![]() Then mounted the tubing on the inside of the instead of on the front like the old one. Also used tubing instead of brass rod. ![]() Forks made out of 1/2 brass with 1/4x1/4 square tubing to allow them to slide. ![]() ![]() ![]() ![]() And 2nd fork and its done just needs some black paint and its good to go.. ![]()
Looks great! Very creative. I like it
Scott
I run a single stack Mack with a dump body on the back! |
Looks good Paul now lets see a video of it in action.
![]() Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
Thanks Scott
Thanks Travis.. Video is pretty hard for me to do since I changed company's for internet are new is cheaper but no good for downloading..
Nice work on the skid steer and the forks are nice addition. How do you keep the load level through the motion? |
I have my stick set up that center is level on the bucket and right is dump and left is raise it works great this way..
Here is a video of the new Grapple bucket I made this weekend it turned out great I have a little fine tuning to do with the servo programer but other than that works great..
http://youtu.be/4bJOshI1w8k
thats cool Paul . you just needed a dumpster to put that crackberry in
Nice work Paul! It works great.
Nice work, very quick movements.
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 |
Thanks Much Scott.. Thanks Chaser it is fast I reprogrammed the bucket and slowed it down now it is nice and smooth also the arm slowed it down a little all the movements are very scale now and work great..
Hey TC ,nice work on the grapple,works great
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Cool build Paul! Its works pretty good!
Brian RIP FreddyGearDrive 2-12-59/12-19-11 |
Looks good nice job Paul.
Travis
Thanks alot Pumpteck.
Thanks Brian. Thanks A lot Travis..
Paul, the grapple is a very cool item! I'm amazed by how much power the small loaders have when converted to RC.
Big iron is awesome! |
