Old 02-10-2012, 11:12 AM
roadranger's Avatar
roadranger roadranger is offline
White Line Fever
roadranger is on a distinguished road
Default Re: Truck steer type lift axle
Thanks for the info, guys!
While the trailer steer axle has enough caster on it to make it self-turning, like fuzzy says the axle AND probably the tierod needs to be cut out to clear the driveshaft. Don't know how cutting and reassembly will work, exactly.
fuzzy- can you keep me updated on how your setup works?
Here's a pic I found; anybody know the size of the tube used, and thickness of the arch?
Brian's idea of using a steer axle might work, if the axle has enough caster in it to self-turn. Got any pics of this setup Brian?
Old 02-10-2012, 03:38 PM
Brian in PA's Avatar
I'd rather be truckin'
No pics Jim. I know that the 1:1 trucks use this set up. You could position the axle to its has caster in it. The truck I'm building now I had thought about doing this setup, but those steering lift axles aren't that common around these parts.
Brian
Old 02-10-2012, 04:05 PM
something like this ?
I pulled it off the log truck do to getteng hung up off road I never got the lift and hanger assembly the way I wanted yet
Old 02-10-2012, 09:45 PM
That's the same problem, that I have with my full size dumptruck
Never have been a big fan of "Training Wheel's"
Cheer's, Neil.
