Here are pics of my Duratoy Conveyor Conversion:
![]() ![]() ![]() ![]() ![]() ![]() ![]() Here's the shopping list! www.servocity.com Dayton gear motor - 25 rpm model -part #2L010 http://www.servocity.com/html/25_rpm...gearmotor.html also get a 3/8 x 5/16 universal joint to connect motor to conveyor shaft - part # COXA1-8: http://www.servocity.com/html/universal_joints.html If you need a 12v power supply, I found a great resource to get one for $11 !!! and it puts out 5 amps! http://www.ebay.com/itm/AC-Adapter-P...item4ab3776482 that is exactly what I used for mine. The only other things I did to it was had some sheet metal bent to raise up the hopper and I cut a 2x6 to size to raise up the lower hopper. I think I also got 10-32 bolts 1.5" long to mount the motor to the hopper.
"If you build it, they will come" East Coast Mini Truckers To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
