Its been awhile since I've built a kit but here goes. It will be a slow build due to time, funds and the lack of tooling (working on that). I'm going with a mid roof, a bit of a stretch, big pipes and any thing else i think of as i go. Here's a couple pictures after I laid every thing out. I started doin' a concept layout so I could get an idea of how long the rails need to be.
That's cool. Knight Krawler though? Going crawling with it, or just playing with night crawlers?
Nathan |
Looking good so far!
Scott
I run a single stack Mack with a dump body on the back! |
Thanks ESPEEFAN, There was one more picture that didn't make it out of the camera showing my work area and my crawler. I chose the name because the crawler migt donate its guts to the Knight before the build is done.
Thanks, Scott The only update is the rails got drilled and I threw some X-mbrs in it last night. I still need to drill and tap the frame flanges but dont have that size drill and tap, and our local tool supply doesn't carry metric bits. ![]() |
Nice concept, a hybrid as such, but not in an economical sense. My favourite kind! Could be an off road logger type of setup. Best of luck with the design and build
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Cant wait to see this rig come together!
Thanks for the comments guys.
Funny how that works huh? My local hardware store couldn't get me 3mm hardware for my build, but they had the drill and tap for it. weird!
Look'n neat with no air in the seat |
Well with Christmas over and just finishing working 46 1/2 hours at triple time during holiday shutdown(?!), its time to get back to work on this project. I did manage to hide out and do a few things over Christmas weekend.
![]() ![]() ![]() Thanks for lookin' Kent |
hide out some more! that skeleton is looking sweet so far!
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Got the suspensions done. Mounted the tires. The rear suspension, at the moment is not fastened to the frame so I can slide it around until I get everything layed out. I still need to get another set of fuel tanks and a set of running board step/box mounts so it all flows with out gaps to fill.
![]() ![]() ![]() ![]() Thanks for looking ![]() Kent |
Yeah now that's what i'm talking about! Looking mean.
This build has taken a couple different turns lately. Every time I set down at the bench a new idea and direction comes along!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() This next set of pictures are mock ups of the new direction I'm going. It will be a tri-axle, I have most of the parts for the axle or need to make them. The deck plate will go all the way to the cab with a headache rack (not made yet). The cab will be a mid-roof, two tone blue, there's a lot of blue Knight Haulers out here but I get a lot of greif from my daughter because everything I buy (1:1) is always some shade of red. Her favorite color is blue. I've got 2 pole trailers one is a donor for the truck and to modify the second one, I'm going to try to do a bridge beam hauler. But as with the truck that can change. ![]() ![]() ![]() ![]() |
Great Job. That's a really neat Idea to have the deck over the wheels. Looks really good.
ECMT Members: Join your Group. Go to your username in the top right corner of the page and click on it. When your profile opens go down to group memberships, Click on East Coast Mini Truckers, The social group will open and scroll down And in the middle it you will see "Join Group" Click on it and then confirm that you REALLY wanna join. [SIZE="2"] |
Thanks John, It will have two sets of pole/log racks, both removable. It will be able to pull a standard trailer or a pole trailer. It can be used as a stand alone truck or tractor.
Now that's useing the ol' noggin'.
![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
Wow, i'm impressed! Well done for taking the leap, this is quite original. With all of the builds going on here, i'm amazed how people keep coming up with something that has not been done before.
Nice loking job!
Don't think you will have any problems with the solder so long as you give it all a good wash in soapy water when you have finished to kill off any flux. Turn table rings look really neat. |
Now is all I need to do is pry myself away from the forum and the computer and get to work! ![]() ![]() |
Hi all,
I've got a few small things done, like mud flap brackets made and the rear bumper mounts modified. Got the 5th wheel mounted through the deck, I'll post those pictures later, still got some details to work out like building and mounting the log bunks. I also started the headache rack. Its kind of raw right now and I still need to cut and build the mounts for it, but its coming along. ![]() ![]() ![]() ![]() Thanks for looking, more later! ![]() |
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
