Old 02-19-2012, 09:45 AM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: Espeefan's slow motion Peterbilt Heavy Hauler build
Man i want one of those! Nice work Nathan!
Brian
Old 02-19-2012, 04:19 PM
Thanks Brian. Means a lot.
Originally Posted by ihbuilder View Post
wow , Nate ,looks good Nothing like having the right tools to do what you want and how you want
Steve, thanks! Hey, when you get around to it, I need some Vortex breathers for this thing, now that it's back on the work bench. From a guy who really knows how to machine. I'm just a novice.
Old 02-19-2012, 04:52 PM
I don't machine like some of the other guys here you only see the good part not the hrs of fustration , for instance , you spend hrs manually doing 1 op on the lathe only to get screwed up in secounds on the mill I realized friday that the coaxial indicator I got is total crap same with the digital caliper after a few hubs (days worth of lathe work ) bearing bores where off . now I'm going to make a different setup jig much like a pallet system .
A/C I'll try to run them this week with rc channel hubs I have to run ( same stock )
