Go Back   RC Truck and Construction > RC Truck's General Discussion. > Get it out of your system! HERE!
Get it out of your system! HERE! You have a gripe,bone to pick, Tamiya vs Wedico or just have to let it out! THIS IS THE ONLY PLACE TO DO IT!
Old 02-19-2012, 08:27 PM
Aero 9000's Avatar
Aero 9000 Aero 9000 is offline
Aero 9000 is on a distinguished road
Default Re: changing gears
Originally Posted by ihbuilder View Post
well start playing around with different turn motors and pinion gears . Put in a grear reduction unit . There are a couple of options for those (GRU ) . In my heavy hual 5900i , I have a 75t lathe motor with a 4:1 GRU . In 3rd gear It'll just keep up to the other trucks in 1st . BUT , If your gona go that low you better beef up the input pinions on the axles when pulling weight (excess of 100#)
I'd want a multi speed GRU, to get lower gears and keep the high ones.
When you say "beef up the input pinions" in what way, different diameter or different material....?? Or change axles completely....??
Old 02-19-2012, 09:28 PM
get the steel pinion from rc4wd for the tlt axle
