Old 02-26-2012, 06:51 PM
ihbuilder's Avatar
Default Re: evercoat poly-flex filler
easy guys I use to have flaking and peeling with evercoat glase ( can't remember the # ) on plastic > my remedy was a good scratching before use and be sure you have your mix right , not to much or to little hardner. I haven't used the new stuff yet as metioned by Spudd , soon though Oh , obviously make sure you have no impurities ie water , oil , etc .
Old 02-26-2012, 08:06 PM
Brian in PA's Avatar
I'd rather be truckin'
Adhesion is only going to happen if the surface is scuffed. this is a must with any coating used in auto body work. the surface has to be scuffed/etched for a mechanical adhesion.
Brian
Old 02-26-2012, 10:45 PM
chaseracer's Avatar
thanks for all the help guys. I did lightly sand the body with 220 grit but either didn't scuff enough of didn't clean it well enough. I will get it figured out I hope
I have always used 3m bondo filler for my other scale rc projects, and never had peeling problem before, but it srinks to much for my liking . I have heard great stuff about the ever-coat so I will get this figured out.
again thanks for the help guys. nice to have forums like this
