Old 03-12-2012, 10:00 PM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Classy Shak
Originally Posted by Brian in PA View Post
Looks good Mike! the tank straps are off the hook!!
Thanks Brian. I got the other straps the other day just have not been home to finish them.
Originally Posted by Cossett View Post
Mike here is a couple of quick pic's till I can get her opened up , but the push rod has two Z on ether end one has a ball join going thought the turn table base plate to the locking arm and then the other end with a z on it goes thought a servo horn ( note the push rod runs under the cross member/s not through them), the micro servo is running parallel to the chassis with a adaptor plate I made to suit the location of the mount.. (I have my servo under the sleeper to keep the back nice and clean)
Thanks Tracy.. I was driving along today and just out of the blue the idea came to me. I will be doing something similar. I figured what I could do is make something similar to the bell crank they make for the steering on the scania's. I can make it out of brass and solder the outer tube into the fifth wheel mount then it would just be a little push rod from the bell crank to the jaws. Move the ball on the jaws from the stock location to where the spring mounts. Then run a push rod from the under side of the bell crank forward to the servo shaft sticking down through the sleeper floor.
Think that will work?
Mike "DREAMWEAVER" Johnson
