Truck Building Tech Covers mechanical and electrical components for truck modeling |
Sounds like you don't have enough adjustment to allow the gears to mesh. Maybe your pinion gear is to small? How many teeth does it have? On the other hand, you could lengthen the motor slots with a dremel or file and see if that helps. Or does the motor bolt pattern not match that of a 540 motor?
Nathan |
The motor sits right atop the tranny and wont go any further, so even if I dremel it, wont make a difference. The pinion is a ten teeth that came with the stock tranny. Has anyone had this problem before?
@ Nathan, Its a 540 can, and the holes appear to match that of the original.
Dont mess with ma trucks To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Thomas,I have a few F-350 tranys running a 10 tooth pinion.You have to grind the mounting holes bigger to drop the motor closer to the trany. Also have to cut top cover so motor can sit down in side of trany.
![]() ![]() ![]() On this one I used a brushless,But it can be done with brush motor. Just don't grind with trany together,remove end plate to do your butchin. Or just run stock pinion. ![]() ![]() Hope this helps! FGD |
Thanx FGD, thats solved the problem. I've noticed the tranny is noisy, have you the same problem?
Dont mess with ma trucks To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Juganought; 09-08-2010 at 06:18 PM. |
