Old 03-15-2012, 03:36 PM
fuchs301's Avatar
fuchs301 fuchs301 is offline
fuchs301 is on a distinguished road
Default Re: 1/14 Grader Caterpillar 12F
thank you for your comments,
The one thing I am a little surprised about is you decided to include some plastic gears in the drivetrain. Were you thinking of doing that for sacrificial purposes, to prevent any damage to other components? The weak link, being the 'fuse'?
Is this grader going to have cab, or will it be an open station model?
@Nathan,
when you look at the tables for strength of such plastic gears (POM), you will find, that the values are not much lower than for normal steel, like C45 (sometimes even higher). I use the plastic gears because they are running quieter.
I buy my gears at Mädler in germany:
http://www.maedler.de/Product/1643/1...1050/1053.aspx
I will make an open station model, because I like this kind.
--- Chris
Old 03-16-2012, 05:53 PM
Fired up Fired up is offline
Fired up is on a distinguished road
Smile Re: 1/14 Grader Caterpillar 12F
great work love to have the tools and skill that a lot off you have keep it up
Old 03-29-2012, 09:49 AM
fuchs301's Avatar
I made a new gearbox for the grader: it is for the transverse movement of the entire blade.
The movable gear segment consists of two halves which are screwed together. This gear segment is driven by a worm gear. After assembly I have mounted the drive motor temporarily to test the function (so you can see my hand in the video).
In this video you can see how it works:
http://youtu.be/1GGAO1b0fa0
--- Chris
