Old 09-08-2010, 12:02 AM
Default Re: Perry's Leimbach Build
I'd stuff that extra valve where the filter can presently is and then put filter can between the reservior & servo. You'll want the left side open to place two AA batt packs for reasonably good run time.
Old 09-08-2010, 12:24 AM
tracksntreadslou's Avatar
You dont want to install the hoes with any kinks and restrict the flow
Hey perry word of advice The first picture with the speed control ...there is a small electrical unit that plugs in to the speed contrrol...If i remember corectly it bolts to the inside of the counter weight with insulated bushinging so it doesnt ground out make sure it is properley installed ...I failed to do so and completely cooked my unit...These are very expensive speed controls ..Mine is now replaced with a sabertooth
